wide tire pictures :)
FnSweet06
nice!
I was thinking of a 305/35/18 then adding some 4:10's and hopefully break into 12's.
69Mach1-409
South Jersey
GT500 Wheels & Goodyear F1 285/40ZR18's out back.
Side-by-side of the OEM's and the GT500's rears.
_M_
Nashville
i wish someone would make a reasonably priced 18x11, these wider tires would really look good and be on a better fitting wheel for their size. steeda missed the boat on their new wheel by making it a 20 vs. and 18
slammed 06
295/30/20 toyo proxe 4's I should have turned the car into the sunlight to show them better. I need a set of those nitto 20" drag radials because it dosen't take much to fire these tires off:evillaugh:
08blackchrome
The problem with running a 265/35 up front with a 305/40 out back is its really going to look awkward because there is a big difference in sidewall and the rear tire will be nearly 2 1/2 taller. I would go with a 265/45 up front much closer but still allows the rear tires to be slightly larger. I run a 305/35 and a 265/40 on 18s
zoomerman46
Vernon,CT
Here a pic of my Nitto 555 295/45/18's on OE Wheels 98 Corbra R Rims. 255/45-18's on the front.
Charlie Sheen
Armed and Hammered
Infernum ubi sum
Not at all
08blackchrome
Im not sure what you mean. I was not even comparing the too tire sizes you have shown. If you dont think a 2 1/2 taller tire in the rear will look awkward then go ahead.
08blackchrome
And That just proves my point that looks hideaus im sorry i know its just my opinion but why the hell would you do that to your car.
Wyld
408 C6
DFW Tx
Shockwave, you are the only person I have seen to make those wheels look good!
