1/4MILEMUSTANG
I have the new style heads on my 06 with a kb blower with E85. What plugs are people running? stock heat range,1 step colder,etc...?
Thanks
Thanks
Autolite HT0 plugs gapped to .32-.35 would be optimal.
I used the Ford Racing plugs, one heat range colder. I have heard great things about Brisk plugs too. I have a 2.6 KB with the stock, 9psi, pulley
are you running E85?
.32-.35???? awful big gap....
also what if he's running 20+ psi???
Dave - don't forget I had 2 blown 3V cars.
Always gapped them to .32.
To each their own. I had great success with those plugs at that gap for a combined 120K miles on both cars over several years of ownership for each.
Let me guess, you were a .28 guy, right?
I didn't forget and I will bet you $100,000 you didn't gap them at .32,
E85 likes a hotter plug, so depending on boost levels, you'd make the choice.
I think you mean .032 not .32?! Because if you can get a plug to spark over 1/4" (.25) you've got some hot coils!! Lol
All about that decimal point and zero, eh guys?
I think you knew fully well what I meant.
.032 is the ideal gap for a supercharged 3V running up to 12 PSI.
I doubt on a stock motor he is running 20 PSI, Dave. Unless he is intentionally trying to blow it up or it is an experiment and he wants to see how long it will last before grenading.
That decimal point makes a big difference my friend.
I can't see he's running a stock short block, .032 is fine up to 12 I'd agree, ideal, I disagree, at 8 psi I think .036-.038 is better.![]()
