Caster/camber plates weren't necessary in my case either and I'm lowered 2". I've got my struts spun 180* and camber bolts and my alignment is spot on.
Gabe ! What lowering springs do you have again and how far is your 13 lowered ?
-Rocky
So if your lowered approx 1.5-2.0" with the added weight of your S/C, I'd say your doing pretty damn good at -1.7 camber without having to spin the GT500 mounts 180* and especially without having to use adjustable camber bolts![]()
Consider yourself fortunate then.. In my case it took spinning the GT500 strut mounts 180* and also maxing out the adj settings of the camber bolts in order to get within factory alignment specs of -1.1 degrees camber.. And I'm lowered by just 1.3 inches with Eibach pro kit springs..
Yeah I haven't re-checked the alignment since the blower went on, so there's a chance it's got more negative camber in it these days.
I'm hoping to eventually put some GT500 springs in it in the front, which will raise the front a half-inch or so.
Yeah, right? My alignment guy said I didn't really need the camber bolts unless I wanted it to be perfect.
The picture in my signature is 285/30-20's on 20x10" +48MM American Muscle AMR's. There's absolutely room for a 285/35 or even a 295/35 and they clear big brakes.
Who's squeezed bit more than 275/35 on 9.5's all around? Or even just the rear, slightly staggered... not a ton like a 285/35 or 295/35
