Wiring diagram for using cruise control button to activate line locks
07Alloy
Clarion Pa.
As long as you can find the appropriate color wire coming from the button you want to use, then it should work fine. Wouldn't be any different than the cruise button
NA-Stang
AMC #8 aka "The Jockey"
Sweet ass sweet. Thanks!
1bad99
bringing post back from the dead.... anyone have pics of the original first post that was shown when kimmer posted the both ways
46addict
13726548
Lawrenceville, GA
this is for the CC
9k=
here 1 for the horns , looks like it will work .
I used the diagram above to wire the CC off switch to fire my nitrous solenoids, but I can't get it to work. The accessory switch is able to click the relay on & off but when I press the CC off button, nothing happens. Any ideas?
1bad99
that diagrham is only for dedicated accessory right ? or can you also use the off for the CC ?
Wes06
It looks like it's just using a dual position setup. It either activates the relay, or it doesnt
46addict
13726548
Lawrenceville, GA
Does the wire going into pin 86 need to be fused as well?
Is this SPDT switch supposed to be a momentary switch?
edit: never mind, I found 3 position switches that will do the job. There are SPDT momentary switches too but that won't make sense in this case.
sdleo29
Fuse 30, that's the high power feed
SirKoda
Toney, AL
Great write up. Im going to use it for momentary nitrous engage. But as a side note the previous posted pictures are no longer here
46addict
13726548
Lawrenceville, GA
Using the SPDT switch and relay did not work for me and I gave up. I was using a normally open relay and I'm not sure if that mattered.
