Groaning sound when turning steering wheel
LordBritish
I hear weird groaning noises when I turn the steering wheel when stationary or moving slowly.
Is my steering pump going to die on me?
I checked the steering fluid and it's full.
:helpme:
maz030
PA
Does it only make noise when you can't turn it anymore, like when you get to the furthest the steering wheel can turn too?
gorblimey61
My steering was noisy when the tie rod ends wore out, but having said that it was while the car was moving.
LordBritish
No, it makes noise as I turn it.
I don't hear it when the car is moving faster than say 10 mph.
My guess is that the steering pump is starting to fail.
RocketcarX
95% of my weight is fuel
Colorado
Does it do it with the car off? Turn the key forward and crank on the steering wheel
MassMustang
Southeastern Mass
Any updates on this? Mine groans when turning hard left into a parking spot. Doesn't do it any other times.
I have 3 year old (about 5K miles) FRPP FCA's that came with balljoints.
dark steed
Resident noob
Winder, GA
Mine started that after my son parked it in a parking lot that flooded. It's seems to do it only in cold weather, and hasn't done it recently.
MassMustang
Southeastern Mass
Interesting point as mine hasn't dine it recently since it warmed up.
I should've mentioned that I replaced the struts, springs and strut mounts (FRPP) last spring. So they're new. Everything seems torqued down properly.
Another thing you can do that is often overlooked is to replace the power steering fluid. It will break down and absorb moisture and contaminants over time, just like brake fluid or any other hydraulic fluid.
My power steering on my recently purchased work truck was a bit stiff and noisy at idle. It has hydraulic assisted brakes which also shares the same fluid as the power steering. I drained out as much as I could and refilled with Mercon VI (the recommended fluid for that vehicle). Replaced about 2 quarts of fluid. It was slightly better right away and within a week all noise was gone.
