NoviBlownGT Build Update!
sdleo29
Where can I find a tubular bumber like that? Bolts right up or is there modifications needed to fit that??
NoviBlownGT
Boosted Crew
Marion, IN
I got mine from a local guy. Donathen Racing. You can find him online or order one from JPC. Bolt right up after you remove the stocker. He is building me a rear one now. With parachute mount.
NoviBlownGT
Boosted Crew
Marion, IN
Little update:
Darrin went through the trans and found a couple "tight" valves in the valve body. He worked them and I went and got the trans from him. Put it back in last night. Everything is working as it should! Got everything back together. Hopefully get some good weather this week so Lito and I can knock out a tune. Plan is to race at Street Car takeover in Indy this Saturday.
NoviBlownGT
Boosted Crew
Marion, IN
Was able to go out for a little drive today. Sent Lito a log. Everything felt good.
NoviBlownGT
Boosted Crew
Marion, IN
Loaded it up in the new trailer last night. Dropped it off for a full alignment. Picking it back up today. Going to put a new set of injectors in and work on a tune with Lito. Hoping to test this Friday at Muncie.
NoviBlownGT
Boosted Crew
Marion, IN
New seat! Also ordered quick release steering wheel. Getting things ready for the cage install in a few weeks.
NoviBlownGT
Boosted Crew
Marion, IN
Well made my first test pass on new setup. Little foot brake launch. Tune isn't done yet. Let out just before the 660'. IMG_4311.JPG
NoviBlownGT
Boosted Crew
Marion, IN
Well I got a make a couple pulls. Tune is pretty good, nice and safe. Probably add some timing in it later in the year. Next to get to the track and get use to the new setup.
NoviBlownGT
Boosted Crew
Marion, IN
Rail pressure wasn't keeping up with the boost. This is more than likely the issue.
