NoviBlownGT Build Update!
NoviBlownGT
Boosted Crew
Marion, IN
Well after a disappointing year I tore the car down. Sold the blower setup, 8 rib, cams, exhaust, and rear end parts.
Going to have a forward facing manifolds single turbo setup built. Still retain stock rad and fan. Going with a large frame t6 turbo. Haven’t worked out the final details on it yet.
Also ordered a set of custom cams from Todd Warren.
Sold the locker and 31spline mosers. Going to go spool with 33spline mosers. 9in ends and probably some 3.73s
I’ll post up some pics as the parts start to arrive.
swflastang05
Back for More
N. Ft. Myers, FL
Damn man I thought your car was running pretty good! So I guess this means you did not run a 8.999 pass? Well good luck with your new build, and I do agree you need more than 31 spline axles and locker in your car with it making that much power. I have Strange 35 spline axles w/ c-clip elims and chromoly spool in mine w/ 3.73's. You gonna run that same IC with the turbo?
NoviBlownGT
Boosted Crew
Marion, IN
Nope. Traction problems kept my from hitting thay 8.999. Was spinning to 1.5-.6 60s every hit. Still running 9.4-9.5 with the garbage 60s.
I sold the intercooler and all the piping. Not sure what cooler I’m going to run. Treadstone makes a killer “1200hp” unit. 28inch core so I’ll have to really measure to make sure it’ll fit.
NoviBlownGT
Boosted Crew
Marion, IN
7200 in first and second and 7550 in third trapping 146-147.
I was trapping low 150s at about 73-7400 locked. My limiter is at 7450 on the n2bm and 7500 on the tune. I think I could get 155 at 7500 locked. 4.10 rear gear on 28s. If I’m unlocked I can only hit what your getting about 146-147 max before the limiter.
NoviBlownGT
Boosted Crew
Marion, IN
First of the parts are starting to roll in. Had a set of cams specd by Todd Warren come in. Wastegates, crank gears, cam degreeing kit, livernois lockouts.
Hopefully get the cams in and degreed sometime soon.
NoviBlownGT
Boosted Crew
Marion, IN
Well I'm slowy working on the car. Removed the abs system, brake lines, gas tank, brake booster today.
Paul is fabbing me up a custom 12.5Gal fuel cell for the spare tire well. Will retain my Fore pump hat.
Turbo is ordered. It is a bullseye street billet 83/96 V vand unit. 1.30 AR.
Still need to install and degree my cams. May yank engine out to do that and check engine over.
Also need to pull converter out and send back to Circle D for a restall.
Will keep you guys updated once I make some real progress.
NoviBlownGT
Boosted Crew
Marion, IN
Some update pics:
swflastang05
Back for More
N. Ft. Myers, FL
Lookin' good! What's with the yellow tape and marker on the fender? I'm also very interested to see how you like the turbo set up vs. the blower.
NoviBlownGT
Boosted Crew
Marion, IN
Had hard time getting exhaust to fit out the bumper. That was the next option.
