06JET
OK, I have been searching but I can't find an answer to this at least that I can see pertains to my issue. I noticed the front driver side marker light was not working so I put it up on the ramps and found that the pig tail was damaged. I left it on the ramps for a month while i was out of town and when I got back my nGauge had drained the battery. (another issue I won't get into now) I could not find a part number for the pig tail so I went to a U-Pull-It and got one off a ford car that looked like my pig tail on my mustang. It even had the bulb socket separate like mine. I wired it up (2 wires) and it worked. Got out from under the car and all of the marker lights were off. Just so happens that the battery wouldn't start the car so I jumped it off with my wife's van. After all that none of the marker lights work and the drivers side window will bump down when I open the door but will not bump back up when I close it. The passenger side works fine. Are the two related in the SJB or separate issues? I am only home 1 weekend a month and usually have family commitments to take care of so not a lot of time to diagnose the problem. Where should I start?
