Presenting the AWE Exhaust Suite for the S197 Mustang GT. Available now.
Josh/AWE
PA
Presenting the AWE Exhaust Suite for the S197 Mustang GT. Available through AmericanMuscle.com and AWEMustang.com:
  • No compromises: All the muscle with zero drone
  • Proudly engineered, designed, and manufactured in-house, in the USA
  • Max gains of 5 hp and 5 ft-lbs of torque to the crank
  • Touring and Track Edition Axle-back options available
  • Touring Edition features AWE’s proprietary drone-canceling solution, 180 Technology®
  • 4.5” double-walled tips available in chrome silver or diamond black
  • Less is more: clean, non-baffled, straight-through design maximizes performance
  • Handcrafted from U.S.-sourced CNC mandrel-bent .065” wall T304L stainless steel
  • Direct bolt-on system for factory-like simplicity
  • Perfect fitment guaranteed
  • No Check Engine Light - Guaranteed
  • Featuring the AWE Lifetime Exhaust Warranty
Touring Edition Axle-back:
The Touring Edition is the perfect configuration for those who appreciate a hearty muscle tone without having to bear in-cabin drone. Construction of full 3” .065”-wall stainless steel while featuring 180 Technology®, the Touring Edition roars when you want it, and quiet when you need it.
Sound Perfection: 180 Technology® by AWE.
As exhaust gases exit the Mustang GT’s 5.0L engine and flow into an AWE 180 Technology® equipped resonator, they pass through strategically located ports, and into reflection chambers. Sound waves, carried by these exhaust gasses, bounce off the walls of the reflection chambers. By controlling the size and location of the ports and the chambers, we also control when the sound waves exit the chambers. The specific timing of when the reflected sound waves rejoin the main exhaust flow creates a one-hundred-and-eighty-degree out-of-phase sound wave that cancels out problematic frequencies. More on 180 Technology® by AWE in the tab above.
Track Edition Axle-back:
If raw and rowdy are your speed, the Track Edition is your dose of steel. The loudest of the lot, the Track Edition Axle-back retains all the engineering and precision of the Touring Edition, including the 3” diameter tubing, minus the 180 Technology®. The result? Completely raw wake-the-dead level muscle.
These versions are known to get rowdy in the mid range, and may be too much for many. For that reason, these particular versions cannot be returned due to sound preference. Prepare yourself.
Important fitment note:
The factory ball-and-socket clamp is to be reused.
Data:
Tip Options:
All tip options include the AWE logo and double walling to ensure a mirror finish even under hard usage. All tips are individually adjustable, allowing depth into the bumper to be set according to personal taste
4.5” slash-cut diamond black tips
4.5” slash-cut chrome silver tips
What’s in the box?
Complete Touring or Track Edition Axle-back Exhaust, two 4.5” tips in desired finish, all necessary clamps and hardware for installation, and installation instructions.
Questions? I'm here.
theRedStorm
Do you offer this for the roush rear valance? Normal exhausts don't work as the rear valance is positioned more inside than traditional exhaust
Josh/AWE
PA
It's time to secure your deal. Until December 3, receive 15% off MSRP on all AWE Mustang products, valid through participating AWE dealers and at AWEMustang.com.
Josh/AWE
PA
Pipe up and rev ‘em loud.
Tag your rev videos with #AWERowdyRevChallenge on Instagram for a chance to be one of five winners to receive an AWE GearBox.
Follow us on Instagram: @awetuningofficial
Josh/AWE
PA
Congrats to winners of the #AWERowdyRevChallenge.
• Evan Patrick (@sir_schmitty__fahrvergnugen), Touring Edition-equipped B8.5 S4.
• Darian Schubring (@dschubring), Track Edition-equipped Mk6 Jetta 2.5L.
• Dylan Joyal (@435i_stella), Touring Edition-equipped F32 435i.
• Aaron Morris (@aaron_morris_), Touring Edition-equipped S197 Mustang GT.
• Chris Beattie (@canadian_chris), Track Edition-equipped Mk3 Focus ST.
Josh/AWE
PA
Tune in today at 1PM EST for an exclusive interview with Justin Dugan from American Muscle, live on Facebook and Instagram.
