2014 P0345/P0349 Help!!!
ksack
Have a 2014 F-150 motor in my project truck but wiring is mostly same same. I've been having cam sensor issues for about a year now. Main codes are P0345 and P0349 for the CMP21 sensor. The truck runs and drives fine once moving, but I'm unable to get up on the 2 step beyond 2500 rpm and I think the computer is not happy with whatever the cam is or isn't reporting. I'm running the diagnostic tree (linked below) and have found 2 weird things that raise suspicion:
1- Test DR6. Tested CMP 21 as well as CMP 11, and both had resistances of 6 megaohms, well outside the 250-1000 the book calls for. The truck isn't throwing any codes for CMP11.
2- Test DR9. Tested both CMP21 and CMP11 connectors. Both CMP wires had 4.9v and 0.5A when connected to ground. Per the book that would mean an short circuit, but my knowledge of how the 5v reference works and the linked diagram, the CMP21 pin should not be seeing any voltage without it being connected to the sensor?
Anyone have any insight on what my issue may be?
Diagnostic tree
https://s197.lima-city.de/index2d64.html?591&viewfile=Camshaft Position (CMP) Sensor.pdf
Wiring Diagram (page 4)
https://s197.lima-city.de/indexb409.html?710&viewfile=024 - Electronic Engine Controls - 5.0L.pdf
ksack
Bump. Still having the same issue with the CMP wires having 5v. My understanding is that because the sensor gets a 12v supply through VBPWR, no 5v reference is needed and the CMP wire should be the signal back to the PCM. Check the PCM and the 5v is present at the PCM pin with harness disconnected. I took the cover off the PCM and saw no apparent electrical damage.
07gts197
Naples, Fl
What is your project truck and what ecu are you running?
on3_5oh
did you ever figure out the issue? i am having a similar issue. Both of my cam sensors are not getting a 12v power supply from the PCM. there are no breaks in the wire. Did you end up replacing the ecu?
