timing chain ?
whitmanink
denver pa
hey guys ,,
im trying to find a complete timing kit for my 09 gt,,
so far all im seeing is timing kits for the 5.4 4v , or 5.4 3v..
are they all the same>? the 4/.6 and 5.4?
if not can someone point me in the direction of a ford complete kit?
Rick Simons
hey guys ,,
I got my timing set at Jegs.
The 5.4 has a higher deck height, thus the chains are longer.
Rick Simons
Forgot to mention:
If you use anything other than OEM Ford for the timing components you're asking for trouble.
whitmanink
denver pa
thanks guys,, and thanks alot dino... i saw that kit on amazon but it says made in china so i wasnt too sure what was the deal..than the rest i saw only said 5.4
as said above , i only want to use ford parts , i watched alot of this guy on youtube, (ford mikiloko ) or sumthin like that and he says only use ford parts, so thats my plan ,,,
2526Bullitt
When I replaced my timing chain components ( chain, guides, tensioners and cam sprockets) I used all ford parts. Moreover, I followed the video from: ford tech makuloco (search his YouTube channel) and it gives you a step by step guide. Take your time and when you have put everything together, make sure to rotate the crank several times to make sure everything remains in time.
whitmanink
denver pa
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Freedom racing used to be a vendor on here. They buy OEM ford parts in bulk and have pretty good pricing. I've bought most of my timing parts from them.
