2010 HID to 2013 HID/LED Headlights?
vxr500
I put this in the 5.0 section because its probably more common among 2011-14's. I know they make a kit now to add 2013-14 headlights to 2010-12's that came with halogens, but is there anything yet for those of us with the HID option? I'm not into rewiring everything. Just looking for a plug/play kit if it exists.
BizJetTech
Sunny Florida
Following - I have a 2010 with the standard halogen headlights - I'd like to learn more about the "kit" for installing the 2013-2014 headlights into my 2010.
pass1over
I like it LOW
Trenton, FL
if you already have HIDs on your 11/12 and want 13/14 headlights, you should be able to change out to a 13/14 HID housing. I got some 15+ look alike housings off ebay for cheap because my '12 housing were so hazed over and sanding them wasn't working anymore.
They were total plug and play, and the 3 led strakes on each side function as running lights and sequential turn signals.
vxr500
So I can just buy 13/14 lights and plug them in? I thought there was some different wiring with the LEDs.
pass1over
I like it LOW
Trenton, FL
Seems like you do need a conversion harness. Apparently the 13 lights use as different style connector.
