2007 4.0 V6: Throttle Bog & Various O2 Codes ?
Dacoda Williams
Virginia
Afternoon, I've got myself a 2007 V6 Mustang. Just started working the car back together for my nephew, so he can use it as his first car. In the last 6 months I've replaced the transmission, threw an axle-back on it, and replaced the EVAP canister. After prepping the car for its first road journey in over 2 years I'm yet stuck again after some disappointing results. The car seems to rev fine and do great under no load (Park/Neutral), but once its actually in gear it REALLY doesn't like to do anything, it will BOG/Hesitate and then catch and seem to run fine. I'll post a video along with a scan of the current codes. I'm really confused as to why I have BOTH a P2196 and p2197, which one is bank lean and the other bank is rich ??? Any help at all would be greatly appreciated.
Link to a video of what is going on, In the video I go WOT and you can see a 5-6 second delay before anything happens:
86GT351
Sunny South Florida
You need to watch live data and see if the sensor is switching from rich to lean while running.
Dacoda Williams
Virginia
Got ya, based on what data I get what would you recommend next? I may be able to check her out tomorrow afternoon, I can drop the datalog file if that would help too.
wildlifeguy
For now, I wouldn't worry too much about the sensor 2 because it should not affect driveability. I think a start would be to see what the o2 sensor voltages look like when running. Watching a graph of both sensors next to each other, they should look very similar consistently switching voltage from low to high. In my limited experience, if a sensor is stuck at 0v or 1v and not oscillating, then it is probably a bad sensor. Maybe first, for grins, clean the Mass Airflow Sensor. Are you getting any misfires? I bought a cheap OBD2 bluetooth adapter and use a free cellphone scanning app and can get some basic useful information from it. Another thing you can do that is fairly easy is switch the 2 O2 sensors and see if the code follows the sensor or stays on the same side.
