TFish2607
I’m currently in the process of doing a complete overhaul and build of several systems in my car as I prepare to attend the Ponies in the Smokies (PITS) in 2025. As I look at some options for my car, I’d like to begin the process of completing a wire tuck and cleaning up some other systems in the engine bay.
With that said, one thought that came to mind was not using the old cooling system rubber hoses and switching to braided lines and AN Fittings. During my research I’ve not found anyone who has completed this before, but may have missed something as I scoured the internet.
I did locate an oil filter relocation kit from MMR that utilizes a -16 AN line water fitting. After locatinf this, I turned to measuring the current diameter water hoses and comparing to the size of the -16 AN fitting they use with their kit. During this I found a 38% reduction in size of the hose when switching to AN fittings.
My first question is, has anyone ever made a switch to AN lines?
Second is, any reason why they would use a -16 AN line and reduce the size of the hose? I’m sure Ford designed it to use a hose that big for proper cooling. I tend to think reducing it would cause the engine to suffer and possibly have cooling temp issues.
Any info or feedback on this would be awesome.
