Buzz1098
Whats the best way in removing this PCV valve? Do I have to remove the valve cover to access? or those the nipple screw out from th valve cover?You should remove the pcv valve if you are going to go with breathers. If you don't it well never vent out of that side because it needs vacuum to open up. Now in most cases it wouldn't be an issue and the PS and oil cap would be sufficient. But with the added cylinder head pressure from the boost you may get some oil drippage or spray with only two breathers. I just got some new replacement valve covers and I'm going to cut the valve out before putting them on. Prolly in a week or two.
