Car was running like shit after trans repair. Had to sit for two months due to family and health problems. Then, Found out both header gaskets were leaking. I could remove top nuts, but can’t work underneath car anymore. Take it to mechanic, he finishes gasket job. In doing so, he swaps upstream O2 sensors. I can fix this with help from kids. Car still runs like shit. Sent datalog to Lito and he says MAF not working. I test everything and find no 5V source going to MAF. All grounds are good. Almost all sensors use a 5V signal from ECM. I test TBPS, and fuel pressure sensor, and they have full 5V. I locate MAF source on pin 25 of bottom ECM connector. I gently clean everything. I have continuity from ECM connector to MAF connector, but no 5V.
It appears that ECM needs repair as pin 25 is dead. Am I missing anything ?
