NEW: LP S197 Adjustable Motor Mounts
Jared@Lethal
NEW: Lethal Performance 05-10 Mustang Adjustable Motor Mounts!
$149.95
http://www.lethalperformance.com/05-09-mus...-mounts-p-30158
Works on all 05-10 Mustang GT's and Shelby GT500's
-Adjustable (Stock Height or 1/2" Drop)
-Allows More Clearance for Aftermarket Superchargers
-Made in the USA
-Aircraft Grade Aluminum
-Easy to Install
-Complete with Hardware and Installation Instructions
The Lethal Performance motor mount was designed with one thing in mind. Adjust ability. The reason we chose that as a platform for our motor mounts is because we found that the standard size motor mount doesn't work for everyone. As an example the 07-10 GT500 customers that want to run a larger twin screw supercharger under the stock hood need more clearance than the stock height mounts offer. A mount with a 1/2" drop to it though is the answer to allowing the customer to fit that blower under the stock hood. So we decided to offer our mount with an additional CNC machined spacer to allow the customer to decide which size mount they prefer to run. Not only does the mount allow for the stock height but the additional upper portion and hardware we supply will allow that mount to be lowered by 1/2". These are a direct replacement for your stock mounts and bolt right in.
Made in the USA with high quality aircraft grade 7075 & 2040 aluminum and custom poured polyurethane.
JSauers
I've got the stock mtr. mounts with a whipple 2.9. If I install these mounts, can the Ford Racing strut tower brace be installed? Thanks.
Jared@Lethal
I can't say for sure. Obviously the 1/2" drop but will it be the 100% fix? Not sure. If you use these and still need a little more clearance you can heat the intake tube up with a heat gun and mold the intake to get more clearance out of it.
Jared
JSauers
Jared, Thanks for the tip. The motor mounts are on the way, I'll post some pics when the job is complete. Thanks again.
rford426
Resident 5.0 H8R
Live Oak,Tx and Tulsa,OK
Nice i know what motor mounts ill be ordering when its that time...Anyone else have adjustables? Or is lethal the only one...I'd like to hear some feedback!
JSauers
Pics of Motor Mount Install Results
Tower Brace, after my new mounts were installed.
Jared@Lethal
3.4 Whipple
For the 3.4L on a GT500 you'll still need the spacer kit as the 1/2" drop from the mounts don't lower the motor enough. Our spacer kit actually includes these mounts in it. So you get 1/2" from the mounts and 1/2" with the spacers which will then give you enough room to clear the stock STB and hood.
Hope that helps.
Jared
windsorcobra
Hope that helps.
Jared
Indeed, thanks. I will definately contact you when I'm ready for my 3.4 purchase
