AC line removal that runs behind engine??
Born To Run
Woodstock,Ontario
How in the hell do you remove this ac line that runs from the driver side fender, behind the motor & over to the passenger side frame rail??
What is holding it? What are the tricks to getting it out??
superman32870
Is this the one you are talking about?
Chris
06 GT Conv
  • Evaporator Outlet Line.pdf
Born To Run
Woodstock,Ontario
AC
Chris
06 GT Conv
Yup,this is it.Thanks.I don't know how i will disconnect the fittings on the firewall,there is no room,i can't even see it from above as i have a KB blower,things are jammed tight back there,any suggestions???
94tbird
4R70W FTMFW
remove the blower. its gonig to be your only option imo
superman32870
If it was only as easy as the diagram makes it look to be!!!!
Chris
06 GT Conv
Matt D
S197 Pilot
Toronto,Canada
I had to remove my intake when I ripped everything out... such a pain in the ass all the lines have weird bends. You need to drain it first of course then start disconnecting a few
Born To Run
Woodstock,Ontario
AC
All my ac stuff is now removed except for the line behind the engine,it can stay there for what its worth.
Matt D
S197 Pilot
Toronto,Canada
did you buy the ford racing ac delete pulley and bracket Randy?
Born To Run
Woodstock,Ontario
ac delete
No,i went with GIJoe(Dave) he is a vendor here,i needed a ac delete with a 8 rib steel pulley,i can also still use a gates green stripe belt as well.He really understands this pulley stuff,he is looking into a power steering option for me as well.Then i can get rid of the stupid power steering lines in front of the rad.
hellion
Banned
let me know if u can come up with something for the ps, ive been wanting to get rid of it but i have not been able to find good info on a manual rack thats a bolt in and does not require fab work
Born To Run
Woodstock,Ontario
ac delete
I will let the forum know if we work something out.
