tensioner clip tool
tmcolegr
It's All About the Build
Central, FL
so let me "check for understanding"....
The steel bodied tensioners are a direct replacement of the plastic bodied tensioners? All the remaining 3V timing components (arms, tensioners, etc.) will work with the steel bodied tensioners? No other changes are required?
Is priming the steel bodied tensioners prior to startup still required?
US-1
Banned
The ShadowLands
Correct.
Nope. Get them in place with a pin of some sorts holding the tensioner arm in the retracted position. Once it is all ready to go, you pull the pin on the tensioner and it will extend to a point where it holds the chains in place for startup oil pressure to reach it. You're going to prime the engine anyway so it's really no big deal.
tmcolegr
Central, FL
Good deal. Thanks for the info.
I have been reading everything I could find on the plastic bodied 3V tensioners and besides being plastic bodied, they don't hold the chains tight while the engine is cranking until oil pressure is acheived.
one eyed willy
Pizzle fo shizzle
Lakeland FL
mine held pressure until i squeezed them to push the oil out, i think they have a check valve in them to allow oil in and keep the oil in. they dont de-pressurize unless you really squeeze the shit out of them.i had to put them in a vise.
