If I just activate the transbrake and push the petal down the car will build about 2psi only. I have to get that turbo going on the transbrake for it to spool. It takes a while to get into boost. By the time I would normally launch on the 3rd yellow light it will only be at 1 - 2psi. I have to sit there for a while to get it higher. When I bracket race, I leave at 2700 and 60' in the 1.8s. I am thinking of adding some nitromethane mix in the meth kit. It should get me more torque down low and get that turbo spooled up faster. I did some research on the Nitrometh and adds some nice power. Snow has it already to go into the water meth mixture and they picked up 30-50whp just from nitrobooster alone. We will see.
Or you can install a small dry shot of nitrous on a MSD digital window switch to activate at 2800 and turn off at 3200 put your 2 step at 3400 and leave the line with boost up already.
Pete
