the ones that don't require adapters for 05-09 should work fine on the 11 shouldn't it?
What are you up to now Beefy???
Everything I've found says they use the same ev14 injectors as the 05+ cars.
vortech?
Would that be a T-trim I spy with my little eye?
The tall EV6's with the USCAR style connectors should fit but I believe you'll need to use the fuel rail spacers that they sell for the GT500 guys that want to run the EV6's. I'll have to double check the height of the stockers tomorrow and verify if they are EV14 or EV6. FRPP also offers a new injector which is a high pressure 47lb EV14 injector. It's what FRPP is using in the new Whipple/FRPP supercharger kits. They are different then the other 47's (GT500) injectors they sell as they are the taller EV6 body. I've been told they have a different spray pattern and handle higher pressure better than the older EV14 47lbers used on the GT500. They're made by Bosch specifically for FRPP.
Here's the link to them
http://www.lethalperformance.com/20...47lb-high-impedance-fuel-injector-set-p-34966
Hope that helps.
Jared
Your always up to no good there beefcake
