dynotech driveshaft not fitting
strong_j
TX^SWAG
Wylie, tx
Hey guys so i bought a used dynotech driveshaft and its not fitting!! when i bolt it up to the transmission it has a huge gap between the driveshaft and rear end!! Is there a adapter i am suppose to use or am i doing something wrong??
Heres some pics!!
thx, joe
rojizostang
i love my cams
san antonio, texas
yes, it looks like you're missing an adapter. did you buy it for a forum member? if nothing else, you can probably get one from the manufacturer.
Natural1
all around duguder
Angleton, TX
Is that thing in ass backwards, as well? It looks like it.. You also need to extend the slip yoke out and get an SN95 pinion flange... SOP (standard operating proceedure)
rojizostang
i love my cams
san antonio, texas
are you sure? doesn't this driveshaft just use an adapter to bolt the shaft to the stock pinion flange?
mine will work either direction, it makes no diff. i had to use a 03/04 cobra flange.
mine is a spydershaft copy
rojizostang
i love my cams
san antonio, texas
linky no worky
the roush drag pak drive shafts have the slip joint at the rear. i been thinking about upgrading to one since i've got light duty u joints
bigwilly43729
I do stupid shit, a lot
Oklahoma: Not terrible
The Shaftmasters shaft I used to have and the Powerhouse shaft I have now both came with adapter plates and the boot was facing the front of the car.
You could PM Powerhouse to see if they can hook you up with a flange. Most of them seem to be the same thing in terms of bolting up to the shaft.
08gt4u
is backwards for sure.all the ones i have seen have the boot in the front
05stroker
Never enough power guy!
Bullard Tx.
Same here , the Coast shaft and the Axle Exchange shaft Ive owned both had the adapter in the rear with the slip joint is the front . Ive never seen a shaft with the slip joint in the rear .
SuperSonic05
Bolingbrook, IL
I have the same driveshaft. you are missing the adapter. I also had a gap, I just pulled the shaft and the u join spreads filling the gap.
strong_j
TX^SWAG
Wylie, tx
Yea I will turn the driveshaft around for sure!! Lol. I just stuck it under there for a quick pic. Ok so does the adapter bolt right up?? Or does it completely replace the rear end flange??
Thx for all the help guys!!
And also this thing pulls out?? Lol. For some reason I thought one piece meant it didn't extend. Lol.
Big50
Vallejo,CA
It has to, your rear end isn't going to stay in the same position. As the rear axle goes up and down it will change the length. If you hold the drive shaft by the short end it will start to pull apart.
strong_j
TX^SWAG
Wylie, tx
Ok guys y'all are right. I have the adapter on it's way!! Hopefully it'll be here soon!!
Mike K
WANNA BE FAST
Richfield, MN
I have a question about this. I put it in and it doesn't bolt in the correct way with the boot up front. Can I just swap u joints around to make it correct?
