T
Top00Cat
Guest
Late model restoration is great. Got my lowering springs, panhard bar, and camber bolts there. Great customer service!
How difficult is the spring install? I definitly need to lower my car, looks like a 4x4!
Not hard at all...Here's the How-To I used:
http://www.mylrs.com/blogs/lrs/arch...ford-racing-lowering-spring-installation.aspx
from what ive seen the weight is nearly the sameSo the FRPP K springs are ok even though the 5.0 is a lot heavier? (Might lower the front more than a 05-10?)
Can I reuse the stock struts and shocks and panhard bar? I know the ride quality will suffer a little bit with stock parts.
Your camber will be off even with a 1.5". The cost of correcting the camber will outweigh buying new tires after you wear out the inner tread
