Tranny issue
Wnt2gofst
Banned
Columbus GA
Well at track after about 7 passes car got to were it wouldn't go into 5th while going down track. All other gears are fine. Slow down and try pit in gear it grinds going in then would kick out of gear. Cooled car off some more and tried putting in gear just idling. Goes in gear but grinds a little. Drive home car goes into 5th now but grinds going in.
Tranny? Clutch? Pressure plate? Any ideas. Syncro? Solenoid?
Sent from my iPhone4 using Tapatalk
VTXFrank
Obama SUCKS!
Santa Rosa Beach, FL
Sounds like a synchro issue to me. But with these newer, electronically controlled transmissions, I can't say for sure. I don't know how much electronics wise the manuals have to them. If this were a car where I knew the limited amount of electrical additions it had, I would definitely say a synchro.
blackgt09
budd lake nj
I had a similar issue with my 09 but it was in second...conclusion was that I completely destroyed second gear synchro doing carlisle burnout comp
Sent from my SCH-I500 using Tapatalk
Wnt2gofst
Banned
Columbus GA
Dealer called said it is covered under warranty and will have tranny out by end day and know for sure what wrong tomorrow
assasinator
1000hp turbo 4v
these transmissions are only rated for 389ish lb-ft. they wont take the power we make for long. im figuring ill have to TKO600 it at some point.
Mikes5.0
Dacula Ga
Man you must have the best dealer in the US. With my luck they would void my warranty if I told them I opened my oil cap.
assasinator
1000hp turbo 4v
http://www.getrag.de/en/235
its actually rated for 500n-m which is less than i said. its 369.
there is the getrag ratings. its called a 6mti500.
6MTI500 (MT82) Transmission 6MTI500 (MT82)
http://www.auto-shanghai.german-pavilion.com/gp/autosh09/exhibitors/profile.cfm?id_nr=9#zoom
Wnt2gofst
Banned
Columbus GA
Dealer didn't give me crap for mods. Least yet. And after last issues I don't thing the will to much. Cold air, and x pipe, that they can see beside some suspension work.
I will be upgrading tranny sooner or later.
assasinator
1000hp turbo 4v
i read that article but didnt pay a lot of attention. i guess i need to keep it in mind.
