Fast64ranchero
I'm looking at both the cast Iron and the Alum. Ford Big Bore blocks, what I need to know is what mods do we have to do to get them into the S197 chassis? from what I read, the Alum block does not have the the water passages for the heater core finished, and the Water pump area is smaller then the 4.6, (impeller hits) what else needs to be done to the alum "cammer" block?
What about the Iron block, same things need to be done? or is it more of a drop in?
what about motor mounts on both, are they the same as the 4.6? Thx
