One of my favorite things about the interior of a gt500 is the snake on the nav screen...
I agree, if your saavy I am sure you can make it do a whole little video when it starts up.
I'd settle for just the engine, the 5.0 is already a thing of the past in my mind.Shit, I need one of those Procharged 6.2 Raptors.
If I can build the same HP with two cams instead of four I'll take the two, not to mention I can punch the fuck out of a 6.2.huh???
Apples to apples, assuming that 550 on the Camaro is at the flywheel
This car will be fast, but I'd be scared shitless driving a car with this much power while not being able to see out of it.... I'd spend the extra coin on the CTS-V (or just get a Z06).
Also, as it pertains to the LSA, call me unimpressed.
550hp should be N/A numbers considering the cubes in question.
I'd personally like to see a lightweight Camaro Z/28 with a light, high compression, high revving 440+hp 5.3 liter... Like a mini LS7!
What a great road race series that would be!
because bmw can put out 500+ hp with a 5.oIf the LS7 puts out 505 hp from 7 liters , why should the 6.2 put out 550?
obviously germ they should cause ford has no many 500+ hp na engines. chevy should take note.
Not impressed with the LS7 either.
IMHO, 7.0 liters in a 'sports car' should pump out 600+HP
We should be asking why they don't pump out more
the 5.4 DOHC All-Alluminum Ford SHOULD be hitting 500 in N/A form.
This is just my opinion, if you both don't agree with it, that's fine with me.
On another note... i case all the 5.0 fan boys missed it...
Hyundai's new 5.0L pumps out more than Ford's "legendary" new 5.0![]()
Yes with a 383 lb ft peak at 6100 rpm.....the LS7....is lighter , smaller, more reliable and makes a LOT more power under the curve. It will also do 600 rwhp N/A without having to promise your first born child.
Germeezy3 said:Even with the 5.0's specific output the 6.2 shouldn't put out 550 hp.
