Cheater Slick Question
classix_stang289
New Jersey
Hey guys im putting on some M&H cheater slicks 28x12.5 15 and will be driving to the track with these on. Now i searched and have seen people running between 11-14psi down the track with slicks but i was wondering what would be a decent pressure on the street for some "stability" while in route to the track. What have you guys had better luck with psi wise down the track with this brand cheater slick? And do these require longer to heat up compared to there Dr's where i only did my burnout for 6seconds at 55-60mph?
See numbers in sig, now would i have an issue with the tire spinning on the wheel at my power level(4.10's as well). I am running a tube with these tires as well.
thanks.:hi:
18-20psi
And they should need less of a burnout. Just a bit less.
now is that psi for street use? what about any issue with the tire spinning on the rim slightly with tubes in place?
Yes street.
I would use a grease marker to index them and see. If they do move a lot you'll need screws.
