Anyone having Issues with JBA?
trbobusa
KY
just wondering if anyone running JBA headers are having any issues with fitment or rattling, pinging etc...re checked it all and still sounds like marbles in the pipes under acceleration...maybe too lean?
trbobusa
KY
Mine fit fine. Sounds like you have something loose or part of your exhaust is hitting something.
everything has been off twice, checked and nothing is touching, only on aceleration is when it does it, not just cruising
bullittrevor
can you be a little more specific on what the noise sounds like? I have jba lt's btw.
trbobusa
KY
sounds like a ping or marbles in the pipes under accel only just cruising make no noise at all, deff not metal to metal
Royski
Are you running cats? I had a cat go bad and it sounded almost like an engine knock under the car.
kevinatfms
EX-ford tech(6 years)
MD
steering shaft may be clear when looking at it but if the engine rolls over without solid mounts it may be hitting the steering shaft or the frame rails.
i have jbas and they fit like crap. the motor mount on the passenger side hit pretty bad and the left side was touching the frame. i ended up cutting them up and making my own tubes...
SD07GT
Just
Busted
Again
How these ass holes are still in business is a miracle !
kevinatfms
MD
once you get them in there they are great, but that is what is expected by going cheaper than the top. they made great power on my car.
