What to install first? Hmmm...
Dark_horse
KC MO
Ok I have a set of bbk udp's, long tubes, and o/r x on the way. I also have a set of stage 2 motha thumpr's on the way as well. What order would you install these? One by one and take note of the increases each part gives. Or just say screw it, clear my schedule and bang this out over a weekend... I'm just trying to get a game plan in my mind... Can't stop thinking about it!
Any comments or ideas welcome... I will also take lots of pictures and post them... Along with videos
BLKBULLITT
Calgary, Canada
your gonna need the entire weekend after a few hospital visits if your doing your headers on your garage floor...
BoostedGT480
Slow 3v
Montgomery, AL
Do all at once. In order to get the full effect of some of the parts, you will need a retune. So unless you want to get a retune for every mod to see the real results, I would just do it all at once
trbobusa
KY
yep, be sure to chime in about those long tubes , let us know how it goes after your done bleeding and crying...lol...JK, took 10 hrs for mine, and 2 hrs to stop crying
Dark_horse
KC MO
Thanks for the input... I love my car to death but I hate crawling underneath it. I'm 6'5" 250lbs, with hands the size of dinner plates, and I can't tell you how much fun it is turning wrenches under there. Hell it's alot of work just getting the damn car in the air. I know it's gonna be well worth it and I can't wait to retire the worn out pirellis that are on there!
06Mach1
I say do the headers one weekend because honestly, you'll be cursing and throwing wrenches across the shop with the header install. I helped install a set on my buddy's GT and it was a nightmare. I'd save the cams and UDPs for another weekend. Those are some pretty labor intensive projects, so I'd budget extra time and possibly a ride to work during the week. lol
CaliStang
sofla
headers are gonna take you a full day if you wake up really early! id do cams and UDP together one day
matt06
St. Louis
ive had the longtubes on and off my car a few times and besides taking a long time to do i really didnt think it was that bad. not sure what brand you have but mine are pipes and went about as easy as possible for longtubes. just try to have someone else there to help hold the headers from the top side while your under the car if not using a lift, makes it alot easier.
19COBRA93
Ford Racing
Clinton, Ut
Good advice here. It's funny, you can spend 15 mins trying to twist, rotate, and force a header into place, but the second you let go, it falls straight to the ground.
Dark_horse
KC MO
I will have an extra set of hands... Just can't wait to get the parts in and get started.
Exhaust first, then cams. Sell the udp's.
Headers will beat you up. Cams are a breeze. You should get some motor mounts to put in while doing the headers.
Dark_horse
KC MO
Why sell the udp's? I got a really good deal on them. is the install effort not worth the results? I also got some prothane motor mounts just didn't mention them.
This is just an IMO. I had them on my original motor. Install is easy. The motor harmonics changed, it got "buzzy". No gains. Nothing bad happened to the motor but when I switched back to the stock balancer the motor was noticeably smoother. I think a good balancer goes along way toward oil pump life.
Anyway it's just a personal opinon based on what I experienced.
