06silverbullet
i lowered my car with k springs and got clunks, now i'm not sure whats causing it as i havent had time to check things out but the rear clunks, and i didn't take the top nut off the struts so what could cause that? i've gone back and tightened everything i've loosened for the most part and it wont stop.
the front suspension clunks but i have a feeling its the struts not being tight enough, question is is there a special tool i should be using to keep the strut from spinning when i tighten the nut on top? it's a pain using two wrenches and i'm not sure i can get it tight enough
