Mystery Light
Joe2006
Hi folks. I live in northern MN, and it has been a very cold couple of weeks. Nighttime temps of -20 F. Unfortunately, my 2006 Mustang GT sits outside. Today we had a heat wave (36 F!!), so I went outside to start the car. I noticed the outside bulb in the taillight on the drivers side was on, and the lens was warm, so it had been on for a while. Car started fine, I pushed the brake pedal, turned on the blinkers and taillights, and everything else in the taillights worked as it should, but this one bulb just stayed on no matter what. I disconnected the battery, then hooked it back up, and the light was off. I pushed the lock button on the key fob, and the light came back on and stayed on until I disconnected the battery again. Any thoughts or ideas as to what may be going on? Thanks.
oldVOR
Northern Virginia
You might have or had water get into the SJB which causes all kinds of electrical issues.
Check in/around the SJB for signs of water intrusion.
