dabad1
does anyone no anything about shaftmaster driveshafts they have 750rwhrsp for$599 im very interested!
When you say adjust do you mean use the spanner wrench to take up the slack in the delrin lining? Do they start making noise after about 150 then and that's how you know?
I think the newer versions of ShaftMaster's drive shafts are direct bolt on's No more adaptor plate to deal with. Great people to deal with.
The 10mm are the bolts at the rear flange?
They probably included a socket because a standard isn't going to fit. When we put my friend's on his car we needed a crow's foot extension, which we didn't have, to get a regular socket on there. There just wasn't enough room otherwise.
Yep rear flange, nothing special about the 10mm socket, just included if you need it. Unless it is made of platnium
10mm socket with the driveshaft:
I guess you are just SOL thenWhat if someone doesn't have a 3/8 ratchet?
