02 sensor 2 Bank 2
Bweathers37
Tehachapi, CA
Hello All, I have a 2014 3.7, just replaced the engine as well as installed a new clutch. First time doing an engine swap solo. Made some mistakes but learned a ton in the process. I pretty much have everything dialed back in and she sounds and feels great. I still need to do crankshaft relearn (P0315)
But I'm also getting code (P0161). I checked/swapped the fuse on that circuit and they look fine, I also replaced the 02 sensor itself. Is there anything else I should check out in that circuit that I may be missing? Or should I just move forward with the crankshaft relearn. Not sure if they are related anymore than just being attached to the same electrical circuit. Thanks in advanced! (First post ever)
