3VNightmare
SOLD- 05-10 3V GT Whipple 2.3 Supercharger (black) Tuner Kit w/ 10 rib Belt Drive
2005-2010 Mustang GT 3V 4.6L Whipple 2.3 Supercharger (black) Tuner Kit w/ 10 rib Belt Drive
- 2.3 Whipple Blower (IAT relocated to the back of the blower manifold) (LOW MILES approx. 1,800 miles on it) (NO throttle body or injectors included)
- Whipple 10 Rib belt drive (includes balancer with 10 rib pulley & used belt) (smallest pulley they had and generates approx. 11-12 psi of boost)
- Coolant crossover w/thermostat
- Heat exchanger w/pump, wiring harness, miscellaneous hoses, & coolant reservoir
- GT500 dual fuel pump w/wiring harness (M-9407-MSVTA) (Fuel sender calibrated for 2010 mustang - pump will assembly will work with 05-10) Will separate fuel pump due to it being year specific
- 2 extension harness’ for the throttle body electronics and fuel rail vacuum sensor relocation kit.
*Does NOT include an intake pipe/filter assembly – this kit was used on a 2010 Mustang and I had to fabricate an air intake that will not fit a 05-09 mustang.
*Does NOT include spark plugs.
*Also,the coolant hoses (aside from heater bypass hoses) were custom routed for my application and may need to be adjusted (cut or some added) to fit your application.
* Does NOT include tune/tuning device.
SOLD
SOLD
