12.34@119 track pass
BlackBeard
Nice run! If I may it seems to me from the video you should warm up the tires a gear higher and really warm them up! what was your 60 on that run, as everything looked real good but that loose traction on the launch. Either way Congrats on an impressive run!!
not bad..... more heat in the tires I'd agree, 2nd gear burnout for 50-55mph on the burnout for 4-5 seconds.
with a 119 trap car should have 111.7-11.9s in it IMHO
post the slip if you have it handy
screamingstang
ill post it in a bit...im not really track racer but man did i have fun....
Bkid
Nice looking car, you get some traction and you will be in the 11`s easily. Your 119 trap speed tells me ,you have a better ET coming soon.
thump_rrr
Montreal Qc,
Trap speed can be deceiving when you spin off the line.
On a 1.62 60' I ran an 11.427 @ 119.98 at E-Town
2nd gear burnout should help a lot.
screamingstang
i will try 2nd gear burn outs when i get the line lock...other wise its useless:damnit:
you ran on 15" DRs and pulled a 2.0 60???
yes you need practice..... seat time is the best mod.... did a lot for me!
screamingstang
yes i did sir....im going to change my tires from 26inch tall to 28's and go back
why change? IMHO unless your forced to shift to 5th ( and you shouldnt be based on your trap) the 26" tire will give you more gear and better launch. Get some more seat time with them, do the 2nd gear burnout, get some heat in them and go for it with a nice 4500+ rpm clutch drop. You should be able, IMO, to get 1.6x-1.7x 60s from those tires, shit if I can pull 1.68-1.70 60s with a 26.4" 265/40/18, you can at least equal that will some practice. :2cents:
