14' A6 Procharger....Need a Converter
BV600
TEXAS
Only did two runs first one I braked at the 1/8th mile and ran a 11.5@99.
Next run went smooth except once my car shifted into fourth it just falls on its face, loses power, I think its the converter locking up? Couldn't get the car to 60' to save my life. Last run was a 11.1@130
stang910
Jacksonville, NC
Those are pretty similar numbers as mine on the stock converter. My first hit with the new converter I ran a 10.4.
BV600
TEXAS
Lund tuning im switching tuners here soon. Boost should be in the 10-11psi range (4.63 pulley).
Bullett
Pwnisher
Mission, TX
Shoukd easily run 10's. Have u track logged?? My best has been 10.7@133 with a 1.79 60 on the stock converter gears drive shaft on stock suspension except bmr springs and steeda lcas, and on 19's front 18" nittos rear 93 pump gas too. On the converter I got the 60 to 1.53 on same mods only adding stall but it's knocking up top and dropping timing quite a bit so it only went 10.5@129. Also on stock gears btw.
BV600
TEXAS
No loggin on the track yet just street. I will have some logs up this weekend. Yep Im still on stock driveshaft. It was my first time out on this setup im sure I can do a little better the next time out. I had my Strange shocks on full stiff and struts on full soft.
Are you shifting into 4th OP?
Yeah I think thats what killed me I rev to 7250ish. It shifted to 4th and felt like it bogged or lost power. I thought it was the converter locking but contacted the tuner and he said the converter locks in 2nd.
Bullett
Pwnisher
Mission, TX
After those track logs Lund will get u in the 10's I've used them as well. Top notch guys. Currently I'm using TSS. Those two tuners will get u there.
FIVE-OH
I'd contact Mike Rousch. He is the best 6R80 tuner out there period!
BV600
TEXAS
Got the trans brake im so I should see 10s this weekend
