19" TSW on Hankook v12s
jayman33
Stage3 is selling the roush trak pak coilovers for $899 which are made by KW. KW tends to be pretty damn expensive plus if they're too harsh a ride you can call them and buy new springs. I have a leak in one the struts and they're repairing and reconditioning it for 100 bucks.
Roush won't give the specs but if you need them call them up and they'll give it to you. It's roughly a .7-1.8 drop and they are pretty harsh.
Do you like the hankook tires? I just bought a set of Forgestars so I have 3-5 weeks to figure out which tires to get.
3.73-11
Perfect stance&fitment imo op sick car what are the future mod plans?
mikeysgt
Bakersfield, CA
Just ordered a new set of tires today. Went with the hankook v12's since I'm not doing any track or racing anymore. Never ran anything other than nitto 555's on my car except for now. Got a set of 275/40/18 and 245/40's for daily use for $650 out the door mounted and balanced. Should be in and mounted on Friday and decided to switch over from my 295/45's and 255/45's since tires are a little cheaper.
blk5.0
good luck finding those rtr parts unless u buy the package from ford also if you do pm me asap.
im afraid your car would sound much louder than that i have a friend with cams and i as well have the ghost cam tune and the real cam is way louder be ready for pure sex
Digital_Synapse
Texas
The ghost cam tune utilizes "real cams". I'm fairly certain you're not talking about a 2011 with aftermarket cams. But you very well could. I just don't know anyone in town running them as it's about $3k said and done, that's half the cost a S/C. The only ones who make them are Comp Cams, and JPC will regrind yours. So unless you're talking about an '11 with Comp Cams, you're comparing two totally different engines. Not apples to apples. All the '10s running around with aftermarket cams usually have long tubes, as they are recommended when going for a more aggressive grind. Soooo if you get a chance to listen to an '11 with LTH, and a ghost cam, then you can compare apples to apples. :)
blk5.0
He said he wants Lt and x pipe and cams. The cammed car I am talking about is a 10 with the set up he wants that's why i said what I said cause his cammed car is ten times louder than the video posted of your car. I was not comparing apples and oranges I was comparing apples and apples. Guess I should of said my cammed friend was an 10.
Digital_Synapse
Texas
I must not be getting through to you. Let me simplify.
^^^^THAT^^^^ is apples to oranges sir. My car does NOT have LTH's. If it DID, then THAT would be apples to apples.
Let me break it down Seasame Street style.
2010: Xpipe, aftermarket cams, LTH
2011: Xpipe, ghost cammed, NO LTH
Not the same comparison. They are two totally different motors. That's why I said find a 2011 with LTH's, Xpipe, and Comp Cams.
Get it now?
blk5.0
Quote:
Originally Posted by 96SN8K
^ JBA LTs with x pipe and frpp cams are next. I'm also thinking of a whipple down the road
Then your car will sound like this. :)
http://www.youtube.com/watch?v=sPaI-...el_video_title
Ok Mr. know it all you said your car will sound like this. well your car is a 2011 his is a 2010 so you compared apples to oranges not me. Also all i said was it will be louder than than the video you posted end of story. Then you took that to another level in which you always tend to do on everything. So next time someone makes a real life comment on 1st hand experience just leave it at that. i never said anything about a 2011 with cams LT or anything that was you. I simply made a statement letting him know your ghost camm car sounds nothing like a 2010 cammed lt x pipe car. Thats ALL and you read into that. You made my statement of" it will be much louder" into a technical more complex thing than it needed to be.
Bnjf
TSW website says they come in 19*10.5 now? Would that fit the 2011?
