20" razors
scottythesparky
All right guys..got rear set of 20x10 razor for the mussy and the offset is +48,I've a 285/30 on there now and it looks like a bloodly rubber band and I have about 15mm to the edge of the guard..I'm trying to get a couple of 315/35/20 that we're take offs of a x5 to see if it will fit,I've fitted a Panhard bar so it's all square as the car is lowered and I can adjust up the height up or down if I need to..just wanting to know what u guys thought on this..any help would be gr8..cheers..:)
Pardue
Lula, GA
The 315/35/20 will fit but is a good bit taller than the OEM setup. I would run a 275-285/35/20 or a 295/35/20. The best size IMO and closest to the factory spec is 305/30/20 but they are crazy expensive.
