2005-2010 Mustang GT 5spd Shaftmasters Aluminium 1 Piece Driveshaft
Status
Not open for further replies.
mustang1200
Badass
Driveshaft has about 600 miles on it. I'm changing the transmission so I won't be using this. This is one of the only direct bolt in units.
Located in Mckinney, TX
Asking $500.00 OBO
Direct Replacement for your Factory Steel Driveshaft
Independently torque tested to over 3900 ft-lb.(click here for test report)
Double balanced in 2 different mounting positions (to ensure vibration free operation)
Utilizes our "proprietary"(Direct Bolt-In rear mounting flange) (NO ADAPTER PLATE)
Made from all new components
Alcoa 6061-T6 aluminum driveline tubing
No need to adjust pinion angle from Factory OEM setting
Shaft Weighs 20 lbs.
1330 series Neapco, High performance rear universal joint
1350 series Spicer, High performance front universal joint
3.5” X .125” Alcoa 6061-T6 aluminum driveline tubing
14HP peak increase, and 16 ft/lb of torque increase
.21 Second Reduction in 1/4 Mile E.T.
Rated to 900 RWHP
Reduce rotating mass
Increase fuel economy
1000’s of satisfied customers
Money Back Guarantee
A driveshaft safety loop may be required in racing applications.
Status
