2006 Mustang "GT" Saleen Supercharged $17,750 OBO
v6tungsten
Wylie, TX
Car was originally V6 Pony package, auto. Now 4.6l, 5 speed with 8.8 rear, 3.55 gears and 50k on GT driveline(Engine, Trans, 8.8 rear end, Saleen supercharger) Always garaged kept since purchased. This 2006 Mustang "GT Deluxe" with Manual Transmission has been treated with Saleen Series VI Supercharger(476rwhp & 450rwtq), With thousands invested beyond the original purchaseprice, low miles, superb maintenance, accident, and damage-free history. $600 exedyclutch kit that will go with car.
More pics https://www.ebay.com/itm/284193149709
See the rear wheel dyno result of this car in the photos!!!!
ENGINE:
4.6L ENGINE (50k) INSTALLED BY HPP
SALEEN SERIES VI SUPERCHARGER 3.4 PULLEY 10PSI (50k)
8 RIB PULLEY SYSTEM
5 SPEED MANUAL
FORD RACING – 47lb FUEL INJECTORS
PROFESSIONAL DYNO TUNE HPP ( from Street Outlaws)
AEROMOTIVE 325 STEALTH FUEL PUMP
KENNE BELL BOOST-A-PUMP
SALEEN COLD AIR INTAKE
PORTED FORD THROTTLE BODY
OIL CATCH CAN
EXHAUST:
FORD RACING – GTA MUFFLERS 4" tips
FORD RACING – SHORTY COATED HEADERS
FORD –H-PIPE
BRAKES:
FORD GT500– 4 PISTON FRONT 14” CROSS DRILLED AND SLOTTED ROTORS
FORD –2013+ 14” CROSS DRILLED AND SLOTTED ROTORS
STAINESSSTEEL BRAKE LINES F/R
SUSPENSION:
FORD - GT500 PERFORMANCE FRONT LOWER CONTROL ARMS
FORD –SWAY BARS Polly Bushing
J&M –REAR ADJUSTABLE POLY UPPER CONTROL ARM
J&M –REAR LOWER CONTROL ARMS
BMR – ADJ RELOCATION BRACKETS
EDELBROCK– REAR ADJUSTABLE PANHARD BAR
STEEDA –SPORT LOWERING SPRINGS
STEEDA –HD ADJ STRUT MOUNTS
KONI –STRUTS AND SHOCKS
DRIVETRAIN:
MGW –SHORT THROW SHIFTER
FORD –RACING 3.55 GEARS 8.8 REAR END
LPW –DIFFERENTIAL GIRDLE
SHAFTMASTER– 3” ALUMINUM DRIVESHAFT
EXEDY – 500 CLUTCH NEW - NOT INSTALLED
FORD – NEW THROWOUT BEARING –NOT INSTALLED
STAINESS STEEL CLUTCH LINE – NOT INSTALLED
ENGINE BAYPARTS /DRESS UP:
HOOD STRUTS
SUPERCHARGER - BATTERY IC COOLANT RESEROIR
FORD – POWERDERCOATED VALVE COVERS
MISHIMOTO- PERFORMANCE ALUMINUM RADIATOR
AFCO -UPGRADED HEAT EXCHANGER
FORD –2013 GT500 SUPERCHARGER COOLANT PUMP
OPTIMUM YELLOW BATTERY RELOCATED TRUNK
ALUMINUM SUPERCHARGER COOLANT RESERVOIR 2.5QT
OIL CATCH CAN
INTERIOR:
FORD -2013 GT500 ALCANTARA / LEATHER STEERING WHEEL
FORD -GT500 DASH PANELS
FORD -2013 MUSTANG LEATHER SEATS
INNOVATIVE– VACUUM/GUAGES BOOST
AEM -AIR/FUEL GUAGE UEGO (new but not installed)
EXTERIOR:
SALEEN EXTREME ALUMINUM HOOD
FORD 2011 BLIND SPOT MIRRORS CUSTOM PAINTED
SHAVED RADIO ANTENNA
FORGESTAR F14 WHEELS 20x9.5 Front / 20x11 Rear
FORGESTAR F14 – ONE NEW SPARE 20X11
GT500S POILER REAR WING (not oem)
SILVERHORSE RACING SIDE WINDOW LOUVERS
SALEEN JP FRONT BUMPER WITH EXTREME SPLITTER – not installed but is available
FORD – BULLIT GRILLE
FORD – OEM GT BUMPER
MUSTANG CLASSIC CHIN SPLITTER – not installed
RAXIOM VECTOR LED Tail Lights (have OEM and smoked lights if needed)
WILL HAVE FACTORY HEAD LIGHTS INSTALLED When Sold
AUDIO EQUIPMENT:
KENWOODDVD HEAD UNIT INSTALLED AND OEM SHAKER 500 AVAILABLE
_zktJS5PTtaleVDCRkBBKg
