Steeda HD strut mounts 2005-2010 Mustang, 2007-2014 GT500 BNIB
TGR96
el blanco nino
Huntsville, AL
SOLD
Brand new, never installed.
These are made to go with the 2005-2010 model struts. Can be used on 2011-14 models if your are using front struts for a 2005-2010 car.
These go for about $280 at LMR. I am looking for $200 shipped to your door in the lower 48, PP fees included.
Please feel free to text me or email me.
256-69 ate - for 813
[email protected]
https://lmr.com/item/ST-5558120/Ford-Mustang-Steeda-Heavy-Duty-Upper-Strut-Mount-Pair
Sorry if the pics are huge. Imgur does this to me when ever I post pics from their hosting site.
From Steeda:
Product Description
2005-2014 Mustang Steeda Heavy Duty Strut Mounts
A heavy duty, direct replacement upper strut mount to replace the weak factory mounts for 2005-14 S197 Mustangs that can be used on the street! The Steeda street heavy duty upper strut mounts are manufactured to the same exacting tolerances as Steeda's industry leading caster/camber plates. They utilize a roller bearing that exceeds OEM specs to ensure precise suspension control. These plates are designed to withstand the punishment of lowered cars unlike the factory piece. They eliminate the "popping" sound that is common on lowered cars when the factory upper mount fails. Unlike the factory piece, you can also get an extra 1 degree of camber in each direction with these plates as well. Steeda's heavy duty upper mounts are specifically designed for street use and will not show any increase in NVH when installed.
Installation Notes
-WILL NOT fit 2011-2014 Mustang V6 and GT with factory strut mounts.
Application
-Fits 2007-2014 Shelby GT500
-Fits 2005-2010 Mustang
-Fits 2011-2014 Mustang with GT500 Strut Mounts
TGR96
el blanco nino
Huntsville, AL
Don't let the name "strut mount" fool you, these are camber adjustable, and are a less expensive alternative to full on caster camber plates. Add some camber with these babies. Plus, they are beefy as all get out!
