- Joined
- Mar 10, 2009
- Posts
- 4,603
- Reaction score
- 1
2005 - 2013 Mustang CPC Battery & Master Cylinder Covers Kit BLOWOUT!!
Uploaded with ImageShack.us
2005 - 2013 Battery & Master Cylinder Covers Kit
These covers are the perfect accessory to hide the battery and master cylinder and clean the look of your engine bay.
These attach to the front of the cowl, each using the two of the “factory” plastic clips that fasten the cowl to the firewall. Made of the same durable, OEM grade heat resistant material to perfectly match other factory under hood components.
Special Note:
*To fit GT500 models, some hand trimming is require to provide clearance around the throttle body, otherwise it fits perfectly.
Proudly Manufactured in the USA by CPC
http://www.modifymystang.com/2005-2013-mustang-cpc-battery-master-brake-cylinder-covers-black/
79.75 SHIPPED after you use the s197 Discount Code- "5%OffS197"
Special Note:
