2005 GT Overheating
nbk13nw
Drove it last night for 5 hours doing some things. Stayed the same. Temperatures stayed between 199f and 201f. When I got into it it I never saw it go above 203f.
Sent from my SM-G925V using Tapatalk
tightwhite08
It could be but one possibility you haven't considered is that there could be air trapped in the cooling system.
The '05-'06 GT models have a bolt in the center of this picture that you can unscrew to bleed the system. Do it from a cold start with the engine at idle speed.
Anyone know where this bleed bolt is on an 08 GT? I don't have this bolt and can t seem to find where Ford may have moved it.
46addict
13726548
Lawrenceville, GA
07-10 had a different thermostat location and lower hose routing so the bleed bolt may not exist.
If it's kicking in the fans at the correct temp I don't think it's your temp sensor. I also thought that the 05 comes with the red anti freeze.
Anybody know where the temp sensor is on these cars? I read it's on the back of the driver's side head?
Boone
Automotive Enthusiast
High Point, NC
Do NOT remove the aforementioned bolt if you run an electric water pump. I can tell you at 55 gpm, antifreeze will hit a fully open hood when you turn the key to the accessory position. It was impressive, but not the "old faithful" I was looking for when I did my motor.
tightwhite08
07-10 had a different thermostat location and lower hose routing so the bleed bolt may not exist.QUOTE]
So if no bleed bolt then raising the front up, filling the coolant at the overflow tank, then squeezing the hoses while the fluid circulates with the car running is how I get any air out (bubbling coming from overflow tank)?
Wes06
It's screwed into the passenger side head in the valley
Lanky0420
Chandler Az
So I checked the belt mapping and it is correct. I pulled the thermostat again and it was correct but I replaced it with the tested / working thermostat. Now to bleed the system. Looks like a squared fitting is needed to remove the bleed valve. Let me see what I can find
Can you offer some guidance on how you got the bleeder bolt loose? Mine is tight and broke my 1/4 inch ratchet wrench. I used some PB Blaster to help, but no luck. Any info would be a huge help!
Lanky0420
Chandler Az
Harbour Freight had an impact bit that worked and I think i got the air bubble out. I'm doing a long drive today to make sure. This thread was very helpful!
whitmanink
denver pa
i think you need to burp the system ,,
anytime its opened up you need to..
you get this kit that you open the coolant res and put this container in and fill a littl with coolant than start the car and let it run till it warm cycles a few times
