lphill01
I had an engine bay fire 4 years ago, installed a “ new”06 body harness and just installed a supercharged 2008 4.6 from a Roush 427R. I’ve got a no crank with a P0685 code. Problem is I can’t find the PCM relay wire on the C172B harness (no wire on pin 37, unless I’m counting wrong), and no leads under the relay on C1035 in the BEC. Am I looking in the wrong spot, or was there a change on the 08 I’m not aware of?
