2006 GT Power Mirrors Not working.
justinsstang
I have tested all the fuses in the passenger side kick panel, all but 2 lit up. I removed the two 10 amp fuses (located directly above and below each other) and tested them and they are good. I'm not sure if they are to the mirror motors or not, but it would make sense since they weren't lighting up when I tested them... I don't really know much about it.
Anyways, other than the switch is there a relay somewhere I can test? I'm pretty sure it's not the mirror motors, I just replaced the complete passenger side mirror (housing, mirror, motor and all) due to a cosmetic issue with the one I had on the housing.
Just curious what else there is to check. Not a huge deal as they're positioned pretty well, but still annoying I have something not working lol.
Thanks for any help =)
86GT351
Sunny South Florida
Did you ever find the issue and get your mirrors working again?
Last activity was 2018. Probably not going to get a response. If you need, start a new thread explaining your issue and someone will probably chime in and try to help.
