Hi, first post here guys. I have a 2011 GT Edelbrock supercharged with an auto. I'm having some issues with the trans and haven't got a solid lead yet. Intermittently on part throttle either manually shifting or leaving it in D the trans will pop into neutral on the 2/3 shift. Car will rev to like 5500 and takes its time before it comes down and goes back into gear. Also, the 2/3 shift is abnormally harsh on part throttle either manually shifting or when I leave it in D. Enough so that it'll chirp the serpentine belt. I read the info on the solenoids from TSB 11-11-11 and it sounded like that might cure it. I replaced the 3 solenoids myself....that didn't fix the problem. Best lead I have right now is that it could be the molded lead frame in the trans itself going bad. I have an e mail to Lund to check the trans tune just to see if anything is out of spec with the tune. Any ideas would help...thanks
