2014 v6 6r80 issues
DK_Busan
South Korea
Hello again from South Korea!
It seems to be two separate symptoms, although I'm not 100% sure—they might be related.
Symptom #1 — Happens only when fully cold & moving for the first time
After a full cold start, I let the engine warm up completely until the RPM settles to normal idle.
Then, as I begin driving:
  • In 1st gear, if I accelerate up to about 1200 RPM and then release the throttle, the car starts surging / jerking, bouncing between 900–1200 RPM repeatedly (like "boong-boong-boong-boong").
  • This only happens when the car is moving.
  • There is no issue in Park or Neutral—RPM falls smoothly there.
  • And interestingly, it does NOT happen in manual (select-shift) mode. When I manually hold 1st gear and lift off the throttle, everything is normal.
Symptom #2
When the transmission is warm (especially after a long drive):
  • In 1st gear, if I accelerate to around 1100–1300 RPM and release the throttle, the RPM hangs for 15–20+ seconds before slowly dropping.
  • Once the car shifts into 2nd or higher, the RPM behavior is completely normal.
  • Again, this symptom also does not occur in manual mode—RPM drops normally there.
Additional notes
  • No DTCs or warning lights.
  • Transmission fluid + filter were replaced, and fluid level properly set.
  • Intake leaks checked (none found).
  • MAF sensor replaced.
  • Multiple ECU resets / relearns attempted.
  • Symptoms remain identical.
Summary
Both problems only happen in automatic mode, while manual mode behaves normally, which makes me wonder if it's related to:
  • torque converter behavior
  • a sticking solenoid
  • valve body logic
  • throttle/airflow control specific to auto-shift tables
If anyone with 6R80 experience has seen similar behavior or can point me in the right direction, I'd really appreciate it.
