2012 Mustang 5.0 - Misfire
2012Five0
Portland OR
2012 Mustang 5.0 183k - Engine failed at 103k (replaced with Ford racing short block) - CAI 92 tune
My buddy bought this new back in the day for 36k back in 2011. He needed money for a tax bill last year, so I took it off his hands. Car ran fine. Trouble shifting at high rpm, damn thing didn't want to shift at 6k, but other than that ran great. I've ran it maybe 3000 miles since last June. I'd more partial to challengers, but I couldn't say no to a great deal, 7500, and I've been pleasantly surprised by the Mustang. It's great.
But last summer, on a hot day, the car was running terrible. I thought the clutch was gone. Very hard to launch. That was the start of my misfire problems. I think it was a 300 random misfire. He'd kept up with the oil changes, but he hadn't replaced the spark plugs since the engine was rebuilt.
I replaced the spark plugs. Stock gap.
Idle was dancing around at stop lights. And then I was running high rpm one day on the back roads and I had misfires at high rpm. Felt all over the place. 303 and 305, cylinder 3 and cylinder 5 misfire.
I took it back to a stock tune and replaced the coils.
Idle still dancing around around. Not stalling. No problem getting going. But at part throttle, 3-4k, I was getting 300 random misfire. But I didn't feel a miss except at idle. MPG down.
I used the blue juice to test for a head gasket failure; it didn't turn yellow. I cleaned the MAF sensor. Seafoamed it. Ran some RP Max clean too.
Idle still dancing around.
I pulled and cleaned the throttle body. Ran RP injector cleaner through it twice.
Idle still dancing around. I can feel the miss. Power and reponse seem better after replacing plugs, coils and cleaning MAF and throttle body. MPG isn't as high as it was when I first got the car. Yesterday, I was running it in one gear going through some corners, letting the rpms control the speed some, maybe 3500-4500, and it throws 300, 303, 305 codes.
I'm currently running stock tune with 87 octane. Idle miss. Not running like a dog, but mpg and power aren't tip top. I can't feel or hear a miss at high rpms. But it's throwing codes regularly. It's been cold here, and it threw a temperature code, something about not getting up to temp fast enough. Been watching the gauge, seems fine, code hasn't come back.
What's my next step here?
JEWC_Motorsports
S197 Junkie
Texas
What thermostat is in it? If its too cold itll do exactly what its doing. Been there done that and went back to stock. Could be the thermostat is stuck open too.
2012Five0
Portland OR
The Obama era SCT programmer is saying 300, 303, 305. 300 more often than not.
99% certain it's the stock thermostat. I don't think the thermostat is related to the misfire, but I thought I'd mention it anyway.
JEWC_Motorsports
S197 Junkie
Texas
If its getting the code for not getting up to temp fast enough (P0128) it 100% will misfire. stuck thermostat or faulty temp sensor.
2012Five0
Portland OR
So the other night I cleared the codes, drove it a bit, pulled the MAF sensor wire like some youtube video said to try, and the car idled rock solid. What does that mean?
stevbd
If you’re still getting random misfires check the engine wiring harness carefully, especially where it attaches to the front passenger side of the timing chain cover. It’s secured tight against the cover at that location and over time my harness had chafed and worn through and 3 wires leading to coil packs were down to the wire and shorting out. The rocking of the engine causes the chafing and also the intermittent misfire, as the wires come in and out of contact with the timing cover. Good luck.
