2013 Mustang GT - left LED foglight out!
TenSpeed
Boss 227..every damn time
Michigan
Looks like I will be going to the dealership soon. Left fog light does not turn on. Just noticed this tonight. Anyone else run into this?
Boaisy
Dark Knight
Memphis, TN
I had a deer run into mine once. Had to get the whole unit replaced.
Must be using the same supplier as GM trucks. I can't remember the last time I saw a GM truck with both running lights working.
superslow86
Placerville, CA
Not a fog light but the light bars in my passenger side head light went out when it rained hard here last year for 3 days straight. It would flicker on and off randomly while i drove. Dealer replaced and no issues since. Any chance water got into the connector or something to that extent?
TenSpeed
Michigan
I really don't know to be honest. Now it appears to be working again, although I think it flickered off for a short while on the drive home, but came back on. I will have them take a look at it.
AJCrader
Glendale, AZ
Sounds like a connection got loose
TenSpeed
Michigan
Finally got the car in today at the dealer. Entire lamp is non serviceable, so they are ordering a new one for me, and it will be installed on Tuesday. Happy and bummed at the same time. Once the car is off warranty, I am sure stuff like that will not be cheap to replace if it happens again. Pretty glad I removed the yellow film off of there before winter, although another set will be installed in the spring.
My day is better than the guy there with the '14 GT/CS that had a blowout on the highway this morning at 75 on the passenger rear. Said the spring, inner wheel well and some other stuff is fucked up. Got it in September and he seemed pretty bummed.
stang8psi
Slower,Lower Delaware
if it does do it again you can always find them used on forums.. they are out there for under a 100 for both so you can have some backups
TenSpeed
Michigan
For the LED lamps? These are not the standard lamps with replaceable bulbs.
