Both those pics show the drivers side which sticks out slightly farther than the passenger by about 3/16 to an 1/8". Still, even when I center the axle the bulge of the tire would probably stick out about 1/16 or so on each side.
Actually, it does bother me because I don't know if it's going to rub when I hit a big bump. I have only taken one drive with it so far. Once I know for sure I will not have an issue on a big hit to the rear suspension, then yes, I would be fine with it.
It's really not that much of a poke, it's about the same as the rtr set up as far as tire to fender space. Not sure if the rtr is a 33 or a 35, if it's a 33 then it is the same as where a 275 would be with them, if the rtr is a 35 then mine sticks out 2mm farther.
What does bother me is that I think the car would look much better if it was about an inch lower. I just can't do that though, it would rub far too much for where I need to go.
